Cloud Managed Networks
How to prevent showing unknown TVs whole casting
This thread has been viewed 23 times
  • 1.  How to prevent showing unknown TVs whole casting
    Posted Jan 24, 2022 01:32 AM
    Hi Guys
    This is an Staff Accommodation environment using IAPs with Central. There is only one SSID and all users and TVs are connecting to same SSID. The issue is while doing casting users are able to see other appartment TVs as well. Is there any way to restrict to show only the respective TV while casting.
    Jacob Makkolil
  • 2.  RE: How to prevent showing unknown TVs whole casting
    Posted Jan 24, 2022 09:48 AM
    You could possibly do something with AirGroup in this case, but in this situation where all users and TVs are connected to the same SSID, it may be challenging to determine which TV belongs to which use. May be best to work with your Aruba partner to explore the options, as this may not be trivial to solve.
  • 3.  RE: How to prevent showing unknown TVs whole casting
    Posted Jan 24, 2022 06:06 PM
    For airgroup based solution, you can refer to this deployment guide as well.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00106566en_us
