Network Management
How to read channel width info in Airwave
  • 1.  How to read channel width info in Airwave
    Posted Feb 07, 2020 08:55 AM
    Under Clients -> Connected I can see channel width column. Many clients show VHT80, but when I click on them Airwave shows:
    Channel Width: VHT80
    Channel Width Capability: VHT 40MHz
    How should I read this? Is the client using 40 or 80 MHz channel width?
  • 2.  RE: How to read channel width info in Airwave
    MVP EXPERT
    Posted Feb 07, 2020 09:10 AM
    Channel Width: = channel widths used by the AP radio.
    Channel Width Capability: = The clients channel width capability.
  • 3.  RE: How to read channel width info in Airwave
    Posted Feb 07, 2020 09:12 AM
    Is it possible to find clients using certain width? Channel Width Capability isn't available in the client table listings
  • 4.  RE: How to read channel width info in Airwave
    MVP EXPERT
    Posted Feb 07, 2020 09:19 AM
    Not quite the info, but the Client Capability report will give you the PHY of clients connected. So from here you can translated this into supported channel width. Might help
    Is there a reason you need to find the info?
  • 5.  RE: How to read channel width info in Airwave
    Posted Feb 07, 2020 09:20 AM
    I'll try that. I'd like to find if any of the clients are using 80MHz as it seems it was left on by default and we'd like to switch to 40MHz width to have more channels.
    Wonder if it causes clients to disconnect if we disable 80MHz width during day time?
  • 6.  RE: How to read channel width info in Airwave
    MVP EXPERT
    Posted Feb 07, 2020 09:25 AM
    I've never had any issues with changing the channel width. That being said, within the User Guide certain AP models (200 Series, AP-205H, 210 Series, 220 Series, 270 Series and 320 Series access points) will trigger a radio restart if the 40/80 channels are modified under the High-throughput SSID Profile.
    Play it safe and do it out of hours
