i am enter to enable mod in aruba controller 620 but now i dont have enable password pleas its urgent for me its task given by my boss pleas help me how to reset enable password
thanks alot.
dear sir
i can acess all the mods but i cant make any changes evev i cant se che show run comand pleas help me why is this happend
Once you chance the password you need to exit out and re-login
Dear Sir.
i cant change the user name password even i cant apply any comand you can see in the picture
Exit out of the global config and re-enter again.
When you do the recover password you get limit access and to regain full access you have to exit out and re-login again using the password you just set.
Ohh I see you haven't made the change yet.
So go and execute the following :
- mgmt-user admin root <hit enter> , then is going to prompt you to enter a new password / verify new password
- Once you do that exit and re-enter
