How to remove AP-275 which are provisioned as air monitors
  • 1.  How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 12:03 PM
    Hi all,
    Recently I installed three AP-275 access points on controller which is running OS 6.4 and unfortunatly APs are showing under air monitors. Kindly help me to reprovision those as AP default profile.
    Darshana priyanjan
  • 2.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 12:05 PM
    Go to AP installation, select the 3 APs and provision them to the appropriate group.
  • 3.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 12:10 PM
    I did it and no luck at all. Even I removed aps from the data base using CLI. But still the same. I think they are not provisioned under any AP profile but air minitors.
  • 4.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 12:07 PM
    You'll also want to make sure you're providing 802.3at power and have LLDP turned on in the switch. If you don't provide this power the AP will shut down the radios.
  • 5.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 12:12 PM
    Thanks and I'll do it tomorrow and see. May be that will be the issue. They are on external poe adepters for ur info.
  • 6.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 01:16 PM
    there might be an issue with their country settings, if no channels are allowed they fallback to airmonitors i believe. which country is the system setup for?
  • 7.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 12:14 AM
    Place is in UAE (United Arab emirates)
  • 8.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 28, 2014 05:09 PM
    If using external Poe injectors and the switch is Poe be sure to disable Poe in the switch as I've seen that cause issues.
  • 9.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 12:45 AM
    All are on non poe switches.
  • 10.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:16 AM
    Type "show ap database" to see if your access points have flags.  Also, what is the exact version of 6.4 that you are running?
    Check to see if your APs will work in your regulatory domain using the command in the post here:  http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-check-allowed-channels-for-an-AP-with-respect-to/ta-p/176776
  • 11.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:41 AM
    Can u see any issue with this
    (MIRS-WLAN-CONTROLLER) #show ap allowed-channels country-code AE ap-type ap-225
    Allowed Channels for AP Type ap-225 Country Code "AE" Country "United Arab Emirates"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (indoor)   36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11
    802.11a 40MHz (outdoor)  100-104 108-112 116-120 124-128 132-136 149-153 157-161
    802.11a 80MHz (indoor)   36-48 52-64 100-112 116-128 149-161
    802.11a 80MHz (outdoor)  36-48 52-64 100-112 116-128 149-161
    802.11a (DFS)            52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    Allowed Channels for Country Code "AE" Country "United Arab Emirates"
  • 12.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:45 AM
    Show AP database --- command
    AP Database
    Name               Group        AP Type  IP Address      Status          Flags  Switch IP     Standby I
    24:de:c6:cd:36:69  default      105      192.168.50.219  Up 18h:37m:27s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:6a  default      105      192.168.50.186  Up 18h:37m:27s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:6b  default      105      192.168.50.239  Up 18h:37m:28s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:71  default      105      192.168.50.185  Up 18h:37m:29s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:7d  default      105      192.168.50.206  Up 18h:37m:31s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:a0  default      105      192.168.50.203  Up 18h:37m:25s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:a1  default      105      192.168.50.196  Up 18h:37m:27s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:a4  default      105      192.168.50.222  Up 18h:37m:31s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:a5  default      105      192.168.50.77   Down            2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:a6  default      105      192.168.50.211  Up 18h:37m:27s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:ad  default      105      192.168.50.241  Up 18h:37m:29s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:36:ae  default      105      192.168.50.175  Down            2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:5e  default      105      192.168.50.183  Up 18h:37m:26s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:5f  default      105      192.168.50.182  Up 18h:37m:28s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:86  default      105      192.168.50.250  Up 18h:37m:29s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:c3  default      105      192.168.50.244  Up 18h:37m:28s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:cd  default      105      192.168.50.194  Up 18h:37m:24s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:eb  default      105      192.168.50.225  Up 18h:37m:30s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:37:f4  default      105      192.168.50.113  Up 18h:37m:28s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:38:0d  default      105      192.168.50.229  Up 18h:37m:27s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:38:0f  default      105      192.168.50.204  Up 18h:37m:30s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:38:1b  default      105      192.168.50.189  Up 18h:37m:21s  2      192.168.50.5  0.0.0.0
    24:de:c6:cd:47:8a  default      105      192.168.50.179  Up 18h:37m:26s  2      192.168.50.5  0.0.0.0
    ac:a3:1e:c0:45:62  275-Outdoor  275      192.168.50.106  Up 51m:24s      2      192.168.50.5  0.0.0.0
    ac:a3:1e:c0:46:36  275-Outdoor  275      192.168.50.83   Up 51m:21s      2      192.168.50.5  0.0.0.0
    d8:c7:c8:c8:3b:4f  default      175P     192.168.50.119  Up 18h:37m:58s  2      192.168.50.5  0.0.0.0
    d8:c7:c8:c8:3b:5f  default      175P     192.168.50.121  Up 18h:37m:58s  2      192.168.50.5  0.0.0.0
  • 13.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:47 AM
    Version INFO:
    (MIRS-WLAN-CONTROLLER) #show version
    ArubaOS (MODEL: Aruba3600), Version 6.4.0.0
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-02-12 at 12:37:41 PST (build 42258) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.1.0 (build 35189)
    Built: 2012-09-06 16:05:33
    Built by: p4build@re_client_35189
    Switch uptime is 18 hours 46 minutes 13 seconds
    Reboot Cause: User reboot.
    Supervisor Card
    Processor XLR 532 (revision C4) with 1979M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
  • 14.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:55 AM
    Sorry for all the previous posts. I think only issue with this.. Can you help me to get it done.
    (MIRS-WLAN-CONTROLLER) #show ap allowed-channels country-code AE ap-type ap-275
    Allowed Channels for AP Type ap-275 Country Code "AE" Country "United Arab Emirates"
    802.11g (indoor)         None
    802.11a (indoor)         None
    802.11g (outdoor)        None
    802.11a (outdoor)        None
    802.11g 40MHz (indoor)   None
    802.11a 40MHz (indoor)   None
    802.11g 40MHz (outdoor)  None
    802.11a 40MHz (outdoor)  None
    802.11a 80MHz (indoor)   None
    802.11a 80MHz (outdoor)  None
    802.11a (DFS)            None
  • 15.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 01:56 AM
    you need to upgrade to the latest 6.4 to solve your problem.
  • 16.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 02:01 AM
    already upgarded to 6.4 as u can see from the version info that i have posted.
  • 17.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 02:04 AM
    6.4.2.3 has already been declared GA  The version you are running is the first version of 6.4.0.0; it is the first release of 6.4 and was released 2014-02-12.  You need to upgrade to 6.4.2.3 to see if it helps you.
  • 18.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 02:26 AM
    Thanks you so much and now its working with ArubaOS_MMC_6.4.2.3_47524. all accesspoints are online..
  • 19.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Dec 29, 2014 02:29 PM
    awesome
  • 20.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Jan 02, 2015 04:07 PM
    It is a very frequent problem
    when the AP is not add to the regulatory domain in question, pending the update you can change the regulation domain of the APgroup to which the AP belongs (apgroup> regulatiy domain); i it's not a very orthodox method but it help , especially that the update for some countries comes late, so just choose the a regulatory domain close to your country .
    Regards
  • 21.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Jan 02, 2015 05:42 PM
    rchahboune,
    If a user is already running ArubaOS 6.4, on their controller they should only need to download the newest regulatory table .dat file in the DRT folder on the support site.  The .dat file has the updated country regulatory domain information and can be imported on any controller running 6.4.x so that the user can get the newest regulatory updates while avoiding updating the ArubaOS code to support newly approved regulatory domains.
     Instructions on downloading and installing the regulatory table is here:  http://www.arubanetworks.com/techdocs/ArubaOS_64_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Management_Utilities/DownloadableRegulatoryTable.htm
  • 22.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Jan 02, 2015 06:36 PM
    @cjoseph wrote:
    rchahboune,
    awesome ,
    very good new thank you joseph
  • 23.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Jan 03, 2015 04:45 AM
    @cjoseph
    just a quetsion  , if i upgrade the controlleur with a newer version that contain a later Regulatory domain , with witch Regulatory domain the controlleur will work.
    Regards
  • 24.  RE: How to remove AP-275 which are provisioned as air monitors
    Posted Jan 03, 2015 06:35 AM
    The latest version will work.
