How to remove ClearPass Enterprise Eval License Key?
  • 1.  How to remove ClearPass Enterprise Eval License Key?
    Posted Jun 15, 2016 11:48 AM
    Hi all,
    Would like to find out what are the steps to take to remove evaluation ClearPass Enterprise License Key in ClearPass Policy Manager > Licensing?
    Thanks in advance.
  • 2.  RE: How to remove ClearPass Enterprise Eval License Key?
    Posted Jun 15, 2016 12:15 PM
    Did you try updating it and replacing with the new license key ?
    Get Outlook for iOS
  • 3.  RE: How to remove ClearPass Enterprise Eval License Key?
    Posted Jan 07, 2020 03:16 PM
    Try this: Administration -> Server Manager -> Licensing
    Select "Applications"
    Click on "Evaluation"
    A new Window pops up and here you can enter the permanet license.
  • 4.  RE: How to remove ClearPass Enterprise Eval License Key?
    MVP GURU
    Posted Jan 13, 2020 07:12 AM
    You can also use API for remove license...
