how to remove the Controller IP in the captive portal address bar without using secured connection?
  • 1.  how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 22, 2017 10:19 PM
    We are mcurrently having a problem in installation in our site.
    When a laptop connects to the wireless network and the captive portal comes up it displays the controller's IP address which is not safe for a public network.
    What do we need to do to solve this issue without using HTTPS:// ?
    When we use the https:// option this problem shows up
    not all clients in the site are techy, so if someone sees this problem appearing they are complaining of a network problem.
    As per the end user they are not going to purchase any certificate for this wireless network.
    BR,
    Carlo
  • 2.  RE: how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 22, 2017 10:30 PM
     - Make sure the controller has an ip address on the guest VLAN
    - Change it so that the controller redirects to that ip address, instead:
    config t
    ip cp-redirect-address <ip address of controller on guest vlan>
  • 3.  RE: how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 22, 2017 10:31 PM
    Somehow I cannot see your pictures.  Can you post them again?
  • 4.  RE: how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 22, 2017 10:55 PM
    This is the first image of the captive portal:
    Here is the image were the end point is using a secured connection:
    Thank you Colin for replying to my inquiry. Notify me if you are not yet able to see the images uploaded.
    BR,
    Carlo
  • 5.  RE: how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 22, 2017 11:22 PM
    Hi Colin,
    Could we use an internal DNS instead of an ip in the guest vlan? How could we do it?
    Br,
    Carlo
    Sent from Outlook on Android
  • 6.  RE: how to remove the Controller IP in the captive portal address bar without using secured connection?
    Posted May 23, 2017 05:40 AM
    By default, the "securelogin.arubanetworks.com" will automatically resolve to the captive portal ip address.  Here is how it works:
    - The default captive portal certificate is "securelogin.arubanetworks.com"
    - Any user that opens a captive portal will ask for "securelogin.arubanetworks.com" and the controller will intercept the DNS query and return the ip address of the captive portal.
    - by default, the ip address of the captive portal is the controller's management ip address.  Optionally, you can change that to any ip address on a VLAN on the controller by using the ip cp-redirect-address.
    - Using the default procedure, no ip address should appear in the browser's address bar...
