Network Management
How to rename a big amount IAPs through airwave?
  • 1.  How to rename a big amount IAPs through airwave?
    Posted Oct 12, 2016 02:09 PM
    Hi folks,
    as already mentioned in the subject:
    How do you rename a big amount IAPs through airwave?
    We've a AMP with nearly 800 IAPs and the device name of each access point is its lan mac address.
    Is there a way to (at least semi)auto rename all of them ? Maybe through a csv export/import?
    We're using AMP version 8.2.2.
    Kind regards
    Ed
  • 2.  RE: How to rename a big amount IAPs through airwave?
    Posted Oct 18, 2016 11:02 AM
    No ideas or suggestions?
    I can't be the only one with this problem?
  • 3.  RE: How to rename a big amount IAPs through airwave?
    Posted Nov 09, 2016 01:00 PM
    I just saw this question (I was searching for something else entirely of course)
    From the web-interface, there's always the "click edit, select 'rename' and then retype each AP name as you go" method.
    Otherwise you might ask TAC to see if they can come up with a database-admin script which could do it.
    Renaming in the html-gui is probably safest.
