@Vishnu Mannilwrote:
You can run a client session report for this. One thing to include in the definition is,
Under Advance option click on show and set Include details about every session and Include details about every client to yes.
Now you can specify the time range and run the report.
Note: Since we are including all the data for client, it would be better to divide and run the report. I.e. if you are running for a month divide it to week and run.
Hi Vishnu,
May i had described no too clearly. I'm sorry for that. But commonly, report will show top 10 client with Total MB Used . I need increase more than 10 so "Number of items to include in Client Session ranked list (Greater than or equal to 1)" is what is need :)
And one more question: How can i export top services/application that user had used ? (Example : user 1: facebook, youtube, http . User2: gmail,https,torrent....)
Many thanks for help
