Developer
How to reset hpicfPoePethPsePortPeakPower value?
  • 1.  How to reset hpicfPoePethPsePortPeakPower value?
    Posted Oct 01, 2020 07:35 AM
    PoE switches such as 2930F make available via SNMP these values:
    hpicfPoePethPsePortAveragePower
    (hpicfPoe.mib)
    Does anybody know how to reset/clear these values?
    I have done research and tried several things, with no luck. Thanks.
  • 2.  RE: How to reset hpicfPoePethPsePortPeakPower value?
    MVP GURU
    Posted Oct 04, 2020 03:40 PM
    if you restart PoE ?
  • 3.  RE: How to reset hpicfPoePethPsePortPeakPower value?
    Posted Oct 05, 2020 04:04 AM
    I tried
    {no} interface <port-list> power-over-ethernet
    but the values don't reset.
    Also, that resets the power to the device connected to the port and produces a power peak at boot-up, which is what I'm trying to filter out.
  • 4.  RE: How to reset hpicfPoePethPsePortPeakPower value?
    MVP GURU
    Posted Oct 06, 2020 10:01 AM
    sorry, no idea... need to ask to SE
