Comware
How to route Wi-Fi guest traffic from Aruba AP 515 on separate VLAN
  • 1.  How to route Wi-Fi guest traffic from Aruba AP 515 on separate VLAN
    Posted Mar 25, 2024 10:32 AM
    Hello All, this is my first post here and I'm not network engineer.
    Here is the current physical setup.
    Aruba AP 515 (10 of them) running in control less setup. One is acting as conductor.
    All APs are connected to Aruba 2930m switch.
    The switch is connected to X0 (LAN) interface on firewall.
    Switch runs with default settings, VLAN1 only.
    DHCP is running on firewall.
    What needs to be set up to route guest Wi-Fi on a separate VLAN?
    Will this scenario work?
    On TZ670, set up VLAN sub-interface on X0 (LAN) interface like X0:V30 with its own IP and DHCP.
    On Aruba 2930 tag ports for VLAN 30.
    On Aruba AP 515 specify static VLAN 30 on guest Wi-Fi.
    Robert
  • 2.  RE: How to route Wi-Fi guest traffic from Aruba AP 515 on separate VLAN
    Posted Mar 28, 2024 05:05 PM
    I have all AP's connected to ports 1-10 on 2930m switch. Switch is on default vlan for all ports.
    Created new vlan 30 and tagged ports 1-10.
    Setup wifi network on AP 515 with vlan 30
    Clients trying to connect and cannot obtain IP. DHCP for this vlan is on Sonicwall 670. Sonicwall is configured correctly.
    Any idea what might be the issue?
  • 3.  RE: How to route Wi-Fi guest traffic from Aruba AP 515 on separate VLAN
    Posted Mar 29, 2024 05:46 PM
    VLAN30 needs to be tagged on the link between the 2930 and the firewall.
  • 4.  RE: How to route Wi-Fi guest traffic from Aruba AP 515 on separate VLAN
    Posted 28 days ago
    Thank you. Yes, that what was missing.
