How to see Connection number?
  • 1.  How to see Connection number?
    Posted May 22, 2013 05:51 AM
    Is there any method to see connection number, aka conntrack number? I would like to see the connection stats about the statefull router performance?
    Thanks in advance.
    Husnu Demir.
  • 2.  RE: How to see Connection number?
    MVP EXPERT
    Posted May 22, 2013 06:36 AM
    Try running :
    #show datapath session counters
    Does this provide the output you require?
  • 3.  RE: How to see Connection number?
    Posted May 22, 2013 07:36 AM
    Thanks a lot.
    http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-show-datapath-session-table/td-p/1570
    Also gave detail info. I will look at more detailed.
    Husnu Demir.
  • 4.  RE: How to see Connection number?
    Posted May 22, 2013 08:24 AM
    A minor question comes up?
    According to these stats what is MAX, What is Total. I mean how to understand these values?
    Thanks in advance.
    Husnu Demir.
    Datapath Session Table Statistics
    Current Entries 112826
    High Water Mark 130829
    Maximum Entries 524287
    Total Entries 3963558
    Allocation Failures 0
    Duplicate Entries 0
    Cross linked Entries 0
    No Reverse Entries 0
    Max link length 128
    Aged Entries 3969972
    Stale Entries 0
    PS: I Know this:
    Displays counters statistics including current entries, high water mark, maximum entries,
    total entries, allocation failures, duplicate entries, cross linked entries, number of reverse
    entries and maximum link length.
  • 5.  RE: How to see Connection number?
    Posted May 22, 2013 08:32 AM
    Maximum Entries is the maximum amount the controller can support
    Total is the amount of entries over time that the controller has seen
    You can clear those too by using the clear datapath session counters.
  • 6.  RE: How to see Connection number?
    Posted May 22, 2013 08:37 AM
    So this means that I have about 524287 entry and above this level It will start to drop?
    I have enabled statefull firewall and I am seeing lots of drop? But I know that these flows started from the inside. Can it be early timeout? Is there  a place to see timeout values?
    Thanks in advance.
    Husnu Demir.
  • 7.  RE: How to see Connection number?
    Posted May 22, 2013 08:46 AM
    Where are you seeing these drops ?
    You should do a show  datapath route and show  datapath route-cache ?
    It depends of what type of timeouts you are looking for?
  • 8.  RE: How to see Connection number?
    Posted May 22, 2013 09:00 AM
    Let me explain a little bit? I am using the controller as a router and wrote an ACL for that. No user database. Today I saw lots of drops on the states that not initiated from inside. e.g.
    udp 17 161 src=10.10.16.139 dst=31.59.94.201 sport=19489 dport=46173 src=31.59.94.201 dst=10.10.16.139 sport=46173 dport=19489 [ASSURED] mark=0 use=1
    related packet dropped by aruba is:
    May 22 16:56:19 :124006: <WARN> |authmgr| {15698740} UDP srcip=31.59.94.201 srcport=46173 dstip=10.10.16.139 dstport=19489, action=deny, policy=wrd_mgmt_dny
    I changed the src IP addresses. So there seems to be something wrong. I like to find it.
    show datapath user counters
    Datapath User Table Statistics
    Current Entries(L2) 0
    Current Entries(L3-v4) 5
    Current Entries(L3-v6) 0
    Total Current Entries(L2,L3) 5
    Pending Deletes 0
    High Water Mark 10166
    Maximum Entries 65535
    Total Entries 20329
    Max link length 4
    Aggregated User Entry Statistics
    Current Entries 5
    High Water Mark 10161
    Alloc Failures 0
    Maximum Entries 12287
    Total Entries 20319
    Invalid/Denied V4 Users 80
    Invalid/Denied V6 Users 0
    Force Delete(IPIP) 0
    Mac Mismatch 0
    User L2 add fail 0
    User L3 add fail 0
    User L2 del fail 0
    User L3 del fail 0
    Pending User del High 10161
  • 9.  RE: How to see Connection number?
    Posted May 22, 2013 09:08 AM
    Please share the output of the following of this command :
    show  datapath route
    And your ACL and where do you have it applied
  • 10.  RE: How to see Connection number?
    Posted May 23, 2013 02:30 AM
    Better not to give public on the list. Can I send this in private?
