Hi All,
I have already install Clearpass Guest, and i put in the portal Secret Question like below :
How i can get DB of guest include secreet ??
Kindly need your advise
thanks
If you want to see it, click on Guest> Manage Accounts> More Options. Click on Choose Columns. Find the field you want and click on Enable Field. When you click on Guest> Manage Accounts, you should see the field as a column.
