Wired Intelligent Edge
last person joined: 11 hours ago
how to see switch device-type on CLI
This thread has been viewed 84 times
  • 1.  how to see switch device-type on CLI
    Posted May 30, 2018 08:26 AM
    hi folks,
    what interessts me for a long time now - is it possible to query the exact switch model on the CLI, for example Aruba 2930M 24G Switch = JL319A (= which can be seen for sure via "show running in the first line")?!
    greets
    Daniel
  • 2.  RE: how to see switch device-type on CLI
    Posted May 30, 2018 09:26 AM
    Hey,
    Try "show tech buffers".
  • 3.  RE: how to see switch device-type on CLI
    Posted Jun 01, 2018 02:25 PM
    Greetings!
    A better, saner option would be this command (with example output):
    switch# show dhcp client vendor-specific
    Vendor Class Id = Aruba JL258A 2930F-8G-PoE+-2SFP+ Switch
    Processing of Vendor Specific Configuration is enabled
    It's a bit non-obvious, but this should get you the info you need.
  • 4.  RE: how to see switch device-type on CLI
    Posted Jun 12, 2018 04:54 AM
    likewise:
    show lldp info local
  • 5.  RE: how to see switch device-type on CLI
    Posted Jun 13, 2018 07:38 PM
    In Addition to the above commands you can get the required information with command "show modules", This will work on all the moduler switches.
    The output will be like below:
    SW2# show modules
     Status and Counters - Module Information
      Chassis: 2930M-24G  JL319A         Serial Number:   XXXXXXXXXX
      Slot  Module Description                         Serial Number    Status
    SW2#
