Couple thoughts/questions:
What version of Clearpass?
Do you have Insight Enabled?
If so, change your Export filter to "Insight Logs"
Data filter to "RADIUS Authentication" > Type to "RADIUS"
Radius.SSID, as well as several others are available there.
If my post was useful, please Accept Solution and Give Kudos.
Zak Chalupka
Principal Engineer - HPE Aruba
ACDX | ACMP | ACSP | ACCP
wifizak@hpe.com------------------------------
Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
Original Message:
Sent: Feb 15, 2024 05:38 AM
Subject: How to send from ClearPass to Syslog location and SSID info
Hi community,
We need that ClearPass will sent a syslog message to Syslog server, caring a session logs which we are seeing in Access Tracker, and specifically Radius request attributes, like location and SSID name.
We can't find related filter in Syslog configuration.
Is there a away to send this information towards syslog? Can 'Option 2' (making a specific SQL query) help with this?
Thank you.
