  • 1.  How to send from ClearPass to Syslog location and SSID info
    Posted Feb 15, 2024 05:39 AM
    Hi community,
    We need that ClearPass will sent a syslog message to Syslog server, caring a session logs which we are seeing in Access Tracker, and specifically Radius request attributes, like location and SSID name.
    We can't find related filter in Syslog configuration.
    Is there a away to send this information towards syslog? Can 'Option 2' (making a specific SQL query) help with this?
    Thank you.
  • 2.  RE: How to send from ClearPass to Syslog location and SSID info
    Posted Feb 15, 2024 05:50 PM
    Couple thoughts/questions:
    What version of Clearpass?
    Do you have Insight Enabled?
    If so, change your Export filter to "Insight Logs"
    Data filter to "RADIUS Authentication" > Type to "RADIUS"
    Radius.SSID, as well as several others are available there.
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: How to send from ClearPass to Syslog location and SSID info
    Posted Feb 19, 2024 02:03 AM
    Thank you @802.zak for response.
    We are currently on 6.11.3 version, and Yes Insight DB is enabled. We'll will definitely try your suggested syslog filter, maybe them will be enough for client.
  • 4.  RE: How to send from ClearPass to Syslog location and SSID info
    Posted Jan 10, 2025 11:35 AM
    Edited by want to become aruba master Jan 14, 2025 01:23 AM
    Try Auth.AP-Name Auth.SSID instead of radius.Accesspoint and radius.SSID
