How to set the Administrator Login session length. The instructions for 6.3 do not work
  • 1.  How to set the Administrator Login session length. The instructions for 6.3 do not work
    Posted Mar 03, 2015 12:49 PM
    I have CPPM 6.3, the instructions and a knowledge article show the syntax to change the administrator login session timeout. As I SSH into the publisher and enter "loginsession timeout 900", for example, I get the following error message: [appadmin@**********]# loginsession timeout 900 ERROR: loginsession: command not supported Type 'help' for more options Same error message for "web-server sessiontimeout 900 Does someone have an answer to this issue?
  • 2.  RE: How to set the Administrator Login session length. The instructions for 6.3 do not work
    Posted Mar 03, 2015 12:50 PM
    This is now configurable in the web UI in 6.5.
    Tim
  • 3.  RE: How to set the Administrator Login session length. The instructions for 6.3 do not work
    Posted Mar 03, 2015 04:11 PM
    Thanks Tim, I really need to change the login session length in 6.3. Do you know how to do that?
  • 4.  RE: How to set the Administrator Login session length. The instructions for 6.3 do not work
    Posted Mar 03, 2015 05:12 PM
    its hard coded you can not.
  • 5.  RE: How to set the Administrator Login session length. The instructions for 6.3 do not work
    Posted Mar 03, 2015 05:21 PM
    Troy, thank you for the information on the hard coded admin session lenght.
    The CLI statements I posted earlier are AurbaOS controller commands; explaining why they did not work on Clearpass.
