Developer
How to set the controller discovery to static using API on the Mobility Master
  • 1.  How to set the controller discovery to static using API on the Mobility Master
    Posted Sep 12, 2018 08:30 AM
    Trying to automate all AP deployment within our organization I am working with the API on our Mobility Master (ArubaMM-VA,8.2.1.1)
    I have been succesfully renaming(ap_rename call) APs using the API and also regrouping(ap_regroup) the AP is working well.
    I thought that the API function (ap_prov) would help me setting the controller discovery to static, but even though I get a succesful respons, It doesn't really seem to do anything.
    This is the response I get from the API, but it doesn't set my controller discovery to static.
    "ap_prov": {
    "ap_name": {
    "ap-name": "a8:bd:27:c5:ce:78",
    "_result": {
    "status": 0,
    "status_str": "NOTE: For cert RAP; ap-name (if specified) in RAP whitelist entry will take the highest preference"
    "ap_group": {
    "ap-group": "ag-TESTGROUP",
    "_result": {
    "status": 0,
    "status_str": ""
    "master": {
    "master": "10.0.1.15",
    "_result": {
    "status": 0,
    "status_str": ""
    "_result": {
    "status": 0,
    "status_str": ""
    "_global_result": {
    "status": 0,
    "status_str": "Success",
    "_pending": false
    Hopefully one of you can help me with this.
  • 2.  RE: How to set the controller discovery to static using API on the Mobility Master
    Posted Sep 19, 2018 05:06 PM
    Check out the work around for changing the controller discovery to static while provisioning an AP mentioned below.
    Method:
    POST
    Request URL
    https://<enter-mm-ip>/v1/configuration/object?config_path=/md&UIDARUBA=<uidaruba>
    Request Body (JSON):
    "_list": [
    "copy_provisioning_params": {
    "_action": "modify",
    "ap-name": "<enter -ap-name>",
    "copy_provisioning_options": "ap-name"
    "set_trust_anchor": {
    "_action": "noop"
    "ap_prov": {
    "master": {
    "master": "<enter-controller-ip-where-AP-terminates>"
    "ap_reprovision": {
    "ap-name": "<ente-ap-name>",
    "reprovision_option": "ap-name"
    Jay
  • 3.  RE: How to set the controller discovery to static using API on the Mobility Master
    Posted Sep 20, 2018 07:08 AM
    Thanks alot, the reprovision did the job :)
