How to Set the name replace IP
  • 1.  How to Set the name replace IP
    Posted Jan 30, 2012 01:29 AM
    Aruba conroller 620 , OS version 6.1.2.7
    Can I add  a name replace IP or Mac Address??
  • 2.  RE: How to Set the name replace IP
    Posted Jan 30, 2012 05:48 AM
    Oh_hab,
    Do you mean in the user table? The only way you can do that is if you authenticate against active directory or ldap
  • 3.  RE: How to Set the name replace IP
    Posted Jan 30, 2012 10:37 AM
    Unless your speaking of provisioning an AP?
    That's under the configuration section, then AP Installation.
    You should be able to change the Name of the AP, and assign it a static IP if you want.
  • 4.  RE: How to Set the name replace IP
    Posted Jan 30, 2012 12:11 PM
    You can use netdestination to map names to an IP addres
    (Aruba651) (config) #netdestination ?
    STRING Name of destination host or subnet
    (Aruba651) (config) #netdestination server
    (Aruba651) (config-dest) #host 1.1.1.1
    (Aruba651) (config-dest) #exit
    (Aruba651) (config) #show netdestination server
    server
    Position Type IP addr Mask-Len/Range
    1 host 1.1.1.1 32
    You can use this name in an ACL instead of the IP address
    For example:
    user alias "server" any permit
