Hi there,
I got this AP so I could extend the WiFi in my house. I have followed many articles and YouTube videos about how to set it up, but I can't make it work. The WiFi of this AP is not running, so I can't connect to it via WiFi, and I also cannot access it directly via it's IP. Moreover, the AP keeps resetting.
I set its IP to 192.168.1.11, both gateway and master IP to 192.168.1.1. I don't know whether that is correct, or should I set something else?
This is the outcome from PuTTY, thanks in advance for any help:
APBoot 1.5.3.9 (build 43867)
Built: 2014-05-21 at 19:31:10
Model: AP-21x
CPU: P1010E, Version: 1.0, (0x80f90010)
Core: E500, Version: 5.1, (0x80212151)
Clock:
CPU0: 800 MHz
CCB: 400 MHz
DDR: 400 MHz (800 MT/s data rate) (Asynchronous)
LBC: unknown (LCRR[CLKDIV] = 0x00)
L1: D-cache 32KB enabled
I-cache 32KB enabled
I2C: ready
DRAM: Configuring DDR for 800 MT/s data rate
DDR: 256 MB (DDR3, 32-bit, CL=6, ECC off)
POST1: memory passed
Flash: 32 MB
L2: 256 KB enabled
Power: DC
PCIe1: RC, link up, x1
dev fn venID devID class rev MBAR0 MBAR1 MBAR2 MBAR3
00 00 14e4 4360 00002 03 80000004 00000000 00000000 00000000
PCIe2: RC, link up, x1
00 00 14e4 4360 00002 03 a0000004 00000000 00000000 00000000
Net: eth0
Radio: bcm43460#0, bcm43460#1
Hit <Enter> to stop autoboot: 0
Checking image @ 0xee000000
Invalid image format version: 0xffffffff
Checking image @ 0xeee00000
Copying image from 0xeee00000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
[ 0.000000] Flash variant: variant0
[ 0.000000]
[ 0.000000] Aruba Networks
[ 0.000000] ArubaOS Version 6.4.1.0 (build 43882 / label #43882)
[ 0.000000] Built by p4build@cyprus on 2014-05-22 at 14:24:44 PDT (gcc version 4.5.1)
[ 0.000000]
[ 0.000000] P1010 RDB board from Freescale Semiconductor
[ 0.000000] Memory: 250004k/262144k available (8904k kernel code, 12140k reserved, 496k data, 358k bss, 5512k init)
[ 0.001490] Brought up 1 CPUs
[ 0.077629] PCI: Probing PCI hardware
[ 0.120676] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 0.183580] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[ 0.245805] pci 0000:00:00.0: not setting up bridge for bus 0000:01
[ 0.320376] pci 0001:02:00.0: not setting up bridge for bus 0001:03
[ 4.190481] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
[ 4.295307] Kprobe smoke test started
[ 4.345233] Kprobe smoke test passed successfully
[ 4.509129] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
[ 4.584216] Amd/Fujitsu Extended Query Table at 0x0040
[ 4.645709] number of CFI chips: 1
[ 4.690129] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
[ 4.772520] gfar_probe: Renaming interface to bond0
[ 4.831281] /proc/gfar_bond0_stats created
[ 4.893364] Enabling watchdog on CPU 0
[ 4.941750] Disabled fips elf aesccm selftest
[ 4.993916]
[ 4.993920] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
[ 5.085678] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[ 5.175344] Starting Kernel DES KAT ...Completed Kernel DES KAT
[ 5.247297] Starting Kernel AES KAT ...Completed Kernel AES KAT
[ 5.291093]
[ 5.336956] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
[ 5.432241] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
[ 5.535446] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
[ 5.639606] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
[ 5.743753] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
[ 5.841077] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
Domain Name: arubanetworks.com
No panic info available
[ 7.014495] AP xml model 84, num_radios 2 (jiffies 3334)
[ 7.078115] init_asap_mod: installation:0
[ 7.126059] radio 0: band 1 ant 0 max_ssid 16
[ 7.178162] radio 1: band 0 ant 0 max_ssid 16
Starting watchdog process...
Got all network [ 9.464487] ADDRCONF(NETDEV_UP): bond0: link is not ready
params from APboot env. Skipping DHCP
Static IP detected. Checking if LACP needs to be configured
[ 15.481884] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
[ 15.555967] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
cat: /sys/class/net/bond0/bonding/mode: No such file or directory
LACP mode set to
192.168.1.11 255.255.255.0 192.168.1.1
Running ADP...Done. Master is 192.168.1.1
[ 66.256332] wifi0: AP type AP-215, radio 0, max_bssids 16
[ 66.352147] Enabling USB power
[ 66.400362] wifi1: AP type AP-215, radio 1, max_bssids 16
AP rebooted Wed Dec 31 16:05:23 PST 1969; SAPD: Unable to contact switch: HELLO-TIMEOUT. Last Ctrl msg: HELLO len=1040 dest=192.168.1.1 tries=10 seq=0
shutting down watchdog process (nanny will restart it)...
<<<<< Welcome to the Access Point >>>>>
radim razzak
