I am setting up different Aruba local controllers throughout our organization. I have setup the follwoing:
1. 2 x Virtual mobility masters (version 8.3.0.3)
2. 2 x Aruba 7030 controllers (version 8.3 in 1 location)
a. Someone else setup the controller out of the box.
b. I upgraded the 7030 devices from 8.0 to to 8.3.0.3
3. 2 x Aruba 7005 controllers (version 8.3 in 1 location)
a. The 7005 came with version 6.5 already installed.
b. I upgraded from 6.5 to verison 8.3.0.3
My questions are:
Q1. If we purchae the 7010 controllers in April 2019, what version is installed from a new Aruba 7010, right out of the box?
a. Will they have verison 6.5 installed?
Q2. Will I require any different serial conneciton settings to connect to the 7010's console port to obtain command line access.
a. I am currnelty using Console Port settings: Baud Rate – 9600, Data Bits – 8, Parity – None, Stop Bits – 1, Flow Control – none.
Q3. Do the Aruba 7010 controllers come with an external power source? I have a power source for 7005 but, I am not sure if it will work for the 7010.
I found this web sitee that may be helpful: https://www.securewirelessworks.com/Aruba-7010.asp?utm_term=aruba%207010%20controller&utm_campaign=Aruba+Networks+*106&utm_source=adwords&utm_medium=ppc&hsa_tgt=kwd-73259964476&hsa_grp=39342681587&hsa_src=g&hsa_net=adwords&hsa_mt=e&hsa_ver=3&hsa_ad=160253173103&hsa_acc=9041622380&hsa_kw=aruba%207010%20controller&hsa_cam=54046741&gclid=EAIaIQobChMIi-3Av43n4QIVksDACh1v1QetEAAYASAAEgJy7fD_BwE
