Wired Intelligent Edge
How to setup a range of VLANs per MSTP instance ArubaOS-CX
  • 1.  How to setup a range of VLANs per MSTP instance ArubaOS-CX
    Posted 4 days ago
    Hi community,
    I need to configure an ArubaOS-CX Switch(6000-series) for MSTP.
    We use four instances with some vlan ranges in our current setup, but "spanning-tree instance x vlan y" only allow one vlan per command. I need to setup ranges of hundreds of vlans.
    On an aruba 2930 it looks like:
    spanning-tree instance 1 vlan 120-147 149-254
    spanning-tree instance 2 vlan 1000-1199 1600-1699 1701-1705 1710 1711
    spanning-tree instance 3 vlan 105 107
    spanning-tree instance 4 vlan 148
    How may I tell spanning-tree instance a range?
    Any help will be appreciated
    Christopher
  • 2.  RE: How to setup a range of VLANs per MSTP instance ArubaOS-CX
    Posted 2 days ago
    Hi Chris,
    The config with the range of vlans for each mstp instance should be the same - the only difference is that you should use commas and no empty spaces between the integers. Here an example:
    spanning-tree instance 2 vlan 1000-1199,1600-1699,1701-1705,1710,1711
  • 3.  RE: How to setup a range of VLANs per MSTP instance ArubaOS-CX
    Posted 2 days ago
    Hi Stanislav,
    works! Thanks a lot.
    It's not documented in CLI guider or interactive help.
