This depends on the SSID you want to create. Are you trying to do 802.1x? If so, you will need a RADIUS server (Microsoft IAS) which can be installed on the domain controller. If you are just trying to do captive portal, you can use LDAP. Both of these configurations should be in the Aruba OS User Guide.
