Network Management
How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
  • 1.  How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted Feb 13, 2015 05:10 AM
    Pls someone help me~
    How can I set up the smtp server using e.g. gmail/yahoo mail, and use that to sent out alert mail?
    Many Thanks
  • 2.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted Feb 13, 2015 06:33 AM
    HI Friend,
    You can configure this in AMPSetup-->General.
    For your ref:
    Please feel free for any further help on this.
  • 3.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted Feb 16, 2015 03:44 AM
    but I have tried to set "smtp.gmail.com" there and use "sent test mail" and nothing happen...
    is there other thing i need to set?
    Many Thanks
  • 4.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted Feb 16, 2015 06:22 AM
    that won't work, google requires authentication to use it's SMTP server which also not running on port 25:
    https://www.digitalocean.com/community/tutorials/how-to-use-google-s-smtp-server
    i believe you will need to configure postfix yourself if you want this to work, this gives a framework, but not the exact config:
    http://community.arubanetworks.com/t5/Monitoring-Management-Location/Configuring-Airwave-to-support-multiple-ISP-accounts/ta-p/185540
  • 5.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted Dec 03, 2015 07:29 AM
    For me this was the best explanation of how to configure and debugg it:
    https://charlesauer.net/tutorials/centos/postfix-as-gmail-relay-centos.php
  • 6.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted May 04, 2016 09:22 PM
    This was the best answer for me. The commands worked, except for one thing: I'm one of the people that turned on a GMail feature to create unique passwords for apps that want to send mail for me. So I had to go to Google's site, create a new app password, and use THAT in the echo command instead. Now things are working!
    Info on how to create a Google app password:
    https://support.google.com/accounts/answer/185833
    Mike
  • 7.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted May 04, 2016 09:27 PM
    You also need to enable legacy authentication on your account as well as import the smtp.gmail.com cert into the trust list.
  • 8.  RE: How to setup alert mail server(e.g. smtp.gmail.com) in airwave ?
    Posted May 04, 2016 10:32 PM
    I don't think I ever activated legacy auth, and I'm sure I never imported a cert. I definitely didn't do either of those things on this last attempt... but it works! :)
