How to setup Mac Authentication on IAP-93
  • 1.  How to setup Mac Authentication on IAP-93
    Posted May 22, 2014 02:52 PM
    Does any one have specific instructions on setting up MAC Authentication for the IAP-93's virtual controller? every thing I have found seems to be for the physical controllers?
  • 2.  RE: How to setup Mac Authentication on IAP-93
    Posted May 22, 2014 03:28 PM
    If you are using the Internal database it is pretty simple.  When you are creating an SSID and get to the Security settings you enable Mac Auth:
    Then populate the internal database with the MAC addresses.  Use the MAC for -both- the user and password:
  • 3.  RE: How to setup Mac Authentication on IAP-93
    Posted Sep 11, 2015 04:20 AM
    Hi ,
    I enebled these, But while connecting, te connection un successful. It shows as deny all on the role.
    but i didnt create a role like this.
