How to setup VLANs
  • 1.  How to setup VLANs
    Posted Aug 13, 2014 04:34 PM
    If I want to create multiple SSIDs each going to a different VLAN, do I just specify which VLAN each SSID should use and then setup the port that the AP is connected to as tagged with all the VLANs I want to use? Or do I have to also specify the VLANs under the  wired profile that is set to the connected port on the AP?
  • 2.  RE: How to setup VLANs
    Posted Aug 13, 2014 04:36 PM
    Are you using controller-based or Instant APs?
  • 3.  RE: How to setup VLANs
    Posted Aug 13, 2014 04:37 PM
    Instant APs connected to a managed switch
  • 4.  RE: How to setup VLANs
    Posted Aug 13, 2014 04:52 PM
    no need to setup the wired port profile unless you are using it.
  • 5.  RE: How to setup VLANs
    Posted Aug 13, 2014 04:55 PM
    On a defaulted AP, there is a wired profile already assigned to Eth0. The ethernet ports will only be used to connect my AP to the network. Does that mean there is absolutely no reason for me to change/add any kind of settings to the wired profile?
  • 6.  RE: How to setup VLANs
    Posted Aug 13, 2014 07:04 PM
    Don't worry about changing the wired profile.
  • 7.  RE: How to setup VLANs
    Posted Aug 14, 2014 12:40 PM
    Got it to work without touching the wired profile. Thanks
  • 8.  RE: How to setup VLANs
    For an instant AP the port needs to be untagged with the management vlan and tagged with any vlans you want to put wireless users in. Then when setting up the SSID you would choose static vlan and input the vlan ID.
