Wired Intelligent Edge
last person joined: 5 hours ago
How to Share multiple VRFs Between Two L3 switches connected using routed interfaces
  • 1.  How to Share multiple VRFs Between Two L3 switches connected using routed interfaces
    Posted 25 days ago
    Hi Dears
    I have two L3 switches in different sites  connected to each other  using WAN Link from an MPLS provider, the first site L3 switch is connected to ISP using a Private IP address, there is a Public IP subnet leased from the ISP, and the Public IP is routed over the WAN Link to the Site-2 switch, in the second site there is firewall connected to the switch using the leased Public IP address, there is OSPF running between site-1 and site-2 and firewall so all route hubs are defined on the routing table including the default route to the ISP from the Site-1
    the firewall forward all traffic to the site-2 L3 Switch  and the Site-2 forwards all traffic to Site-1 L3 switch and site-1 L3 switch forwards traffic to the ISP
    I want to lease another Public IP range from another ISP in the same L3 switch in site-1 and use it in the same second  site firewall in the same  pattern but I found that I couldn't do it using the same default VRF while I was planning I found that I could not share multiple VRFs between L3 switches using same routing mechanism that I am using now
    The attached topology provides a general view of my network.
    I need help with what I can do to make it possible and which technologies I should use.
    The used Switches 6300M
    <quillbot-extension-portal></quillbot-extension-portal>
    Qais Sherfeed
  • 2.  RE: How to Share multiple VRFs Between Two L3 switches connected using routed interfaces
    Posted 24 days ago
    You may use a GRE tunnel over the MPLS network and attach that to the VRF for your second ISP.
