Hello!
We have an AP RAP-155 who do a VPN between an institution and our master network. I suspect a loop on the institution's network and I would like to disable all AP ports remotely on the RAP without cut the VPN link with de AP. Is it something possible? Can I do that with the controller?
Thank you!
Yes. Go to Configuration> Wireless> AP Configuration.
Find the ap-group that your RAP is in and click on it.
Expand AP, click on Ethernet Interface X Port configuration (not 0, because that is the uplink), and Change it to shutdown:
