how to stop rogue DHCP in the network
  • 1.  how to stop rogue DHCP in the network
    Posted Mar 24, 2015 03:01 AM
    How can i stop rogue DHCP in the wired & wireless network?
    Thanks in advance..
  • 2.  RE: how to stop rogue DHCP in the network
    Posted Mar 24, 2015 03:39 AM
    On the wireless you put a rule in like this.
    user any udp 68 deny
    any any svc-dhcp permit
  • 3.  RE: how to stop rogue DHCP in the network
    Posted Mar 24, 2015 06:01 AM
    And for the wired part - make sure that the VLAN you would like to protect on is passing trough your controller.
    and assign ACL role to that VLAN , it will do the trick . (user > any > udp 68 deny>) ... dont forget it will make your VLAN not trusted , so you will need to build a full ACL with allowed services.
    *You may also create an ACL to a spesefic PORT*
    read here more info:
    http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-to-configure-a-port-or-a-VLAN-to-be-trusted-or-untrusted/ta-p/187924
  • 4.  RE: how to stop rogue DHCP in the network
    Posted Mar 24, 2015 06:44 AM
    HI,
    If you look at "logon-control" inbuild policy in Aruba box, first line is to stop DHCP server traffic from the client. "User any UDP 68 deny" means any traffic from a wireless client with dest port as UDP 68 should be denied. hence if any client working as a rouge DHCP will be blocked.
    For your ref :
    Hope you got some more clarity on this.
