Wired Intelligent Edge
How to Storm control on aruba 2930f ?
This thread has been viewed 33 times
  • 1.  How to Storm control on aruba 2930f ?
    Posted Jan 09, 2019 10:48 PM
    Dear everyone,
    Please help me, I want to configure storm control on all port access switch Aruba 2930f ( Broadcast control and unknown unicast control).
    I search on document and try fault-finder command
    hostconfig)# fault-finder broadcast-storm 3 action warn-and-disable 0 pps 150
    And see below:
    Bcast | Port Rising Disable Disable Time
    Port Storm | Status Threshold Action Timer Left
    3 Yes | Down 150 pps warn-and-disable 0 -
    But i want to config all interface port storm control broadcast pps and storm control unicast pps
    I read this guide but can not create:
    https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/How-to-configure-Storm-Control/ta-p/186800
  • 2.  RE: How to Storm control on aruba 2930f ?
    Posted Jan 10, 2019 07:12 AM
    Take a look at the rate-limit command. It is described in chapter 6 of the Management and Configuration Guide.
  • 3.  RE: How to Storm control on aruba 2930f ?
    MVP EXPERT
    Posted Jan 12, 2019 08:09 PM
    I build most 2930F configurations with the following settings. Maybe it will help you with making your choices.
    fault-finder broadcast-storm sensitivity high
    fault-finder bad-driver sensitivity high
    fault-finder bad-transceiver sensitivity high
    fault-finder bad-cable sensitivity high
    fault-finder too-long-cable sensitivity high
    fault-finder over-bandwidth sensitivity high
    fault-finder loss-of-link sensitivity high
    interface 1/1
       rate-limit bcast in percent 10
       rate-limit mcast in percent 10
       exit
    spanning-tree 1/1 admin-edge-port
    spanning-tree 1/1 bpdu-protection
  • 4.  RE: How to Storm control on aruba 2930f ?
    Posted Oct 04, 2022 07:17 AM
    Do you have these same base config options that you've translated to the AOS CX cli?
