Wired Intelligent Edge
how to swap aruba HP 2530-48G Switch (J9775A) switches using GUI
  • 1.  how to swap aruba HP 2530-48G Switch (J9775A) switches using GUI
    Posted Jul 26, 2024 10:03 AM
    Dears,
    I am new to the aruba network.
    Please I need a guide on how to swap how to swap aruba HP 2530-48G Switch (J9775A) switches to another  aruba HP 2530-48G Switch (J9775A) switches using GUI. I have downloaded the configuration from the GUI do do I need to do traditional configuration with console first before I will be able to use the GUI?
  • 2.  RE: how to swap aruba HP 2530-48G Switch (J9775A) switches using GUI
    Posted Jul 26, 2024 10:15 AM
    You need to have information where to find your target GUI so terminal console would be more easier to use..
    • Connect to console
    • Go to configuration context ("conf term")
    • Copy your configuration downloaded from old switch to clipboard using text editor
    • Paste configuration to console
    • Checkout there is no errors there in paste event
    (Done that about 100 times earlier)
    Jori Luoto
    AV-IT Specialist
