Comware
How to Switch Stack Firmware Upgrade Comware 7 HP 5130 JG937A
  • 1.  How to Switch Stack Firmware Upgrade Comware 7 HP 5130 JG937A
    Posted Feb 01, 2018 07:34 AM
    Hi guys,
    I have a HP 5130 7.1.045, Release 3111P02 in a Switch Stack .
    I get how to upgrade the Firmware, my only problem is how do i do this without connection loss of both members?
    At the moment it looks like this
    #Upload the Firrmware to switch
    ftp 127.0.0.1
    #activate binary mode
    binary
    get 5130EI-CMW710-R3208P03.ipe
    get 5130ei-cmw710-packet-capture-r3208p03.bin
    #upload ipe file to flash:/
    #check startup software:
    display boot-loader
    #change startup software to newest build
    boot-loader file flash:/5130EI-CMW710-R3208P03.ipe slot 2 main
    boot-loader file flash:/5130EI-CMW710-R3208P03.ipe slot 1 main
    #verify that new software is set as next startup software
    display boot-loader
    - disable software auto-update
    undo irf auto-update enable
    - save config
    save
    - verify upgrade modus -> incompatible
    display version comp-matrix file system flash:/5130ei-cmw710-system-r3208p03.bin
    - WORKAROUND: hard reboot (both members at the same time)
    reboot
    y
     My Question is how do I reboot 1 Member at a time to upgrade the Firmware?
    I did see some guides where they use the ISSU command but this doesnt exist on this Switch.
    Does it actually work with
    reboot slot 1
    reboot slot 2
    Thank you for your help.
    Best Regards
    Burak
    #stack
    #firmware
    #upgrade
    #comware7
    #HP5130
    #JG937A
    #switch
  • 2.  RE: How to Switch Stack Firmware Upgrade Comware 7 HP 5130 JG937A
    Posted Feb 02, 2018 07:07 PM
    wrote: I get how to upgrade the Firmware, my only problem is how do i do this without connection loss of both members?
    Well...since ISSU on HPE 5130 is not an option you are forced to reboot sequentially your IRF Members to complete the software update procedure therefore a possible way to prevent (connectivity) loss for hosts connected to IRF stack is that those devices (that's primarily related to Servers hosts) are dual homed linked to both IRF Members at the same time (with dual homed linked I mean that an Host should be uplinked to both IRF Members concurrently using NIC ports teaming/bonding/aggregation - call it with the name you like more - using LACP...so one Host NIC link goes to IRF Member 1 and the other to IRF Member 2, on IRF you must define a LAG with LACP exactly like you do that on the Host's NIC to cope with the teaming defined on the Host or viceversa, that's just an example)...and, I would add, that your two members IRF stack adopts a sort of split brain management mechanism (MAD Multi Active Detection) to prevent/manage split brain scenarios that could happen.
    Does that sound logical to you too?
