maybe it would be more helpful if you can provide the whole description of the event where this status codes are appearing so that we can see the whole context.
I suspect however that the status code you have in mind is simply defined in the 802.11 standard so it is not a purely HPE code. Please have a look at this
https://blogs.arubanetworks.com/industries/802-11-reason-codes-and-status-codes/
https://www.cybersecurityinstitute.eu/reference-information1/ieee-802-11-authentication-association-status-codes/
8.4.1.9 Status Code field
The Status Code field is used in a response management frame to indicate the success or failure of a requested operation. The length of the Status Code field is 2 octets. The Status Code field is illustrated in Figure 8-43.
In the table we see indeed a status code 37 and it simply means "the request has been declined" does this make sense for the issues you are troubleshooting?
