Education - Australia / New Zealand
A local community of education customers across Australia / NZ. This group will be moderated by HPE Aruba Networking staff and kept up to date with any upcoming training or events that are relevant to the EDU space.
How to upgrade Airwave 8.2.10 (CentOS7) to 8.2.10.1
This thread has been viewed 16 times
  • 1.  How to upgrade Airwave 8.2.10 (CentOS7) to 8.2.10.1
    Posted Jan 28, 2020 09:57 PM
    1. Make sure you have enough space for disk storage and memory. (You can use df -h and top command to check it). Verify current CentOS version.
    2. Manually Download the upgrade package from aruba support website.
    3. Add file transfer user (Airwave version 8.2.10 or 8.2.4.3)
    Sample airwave commands (step 3)
    4. I use winscp to upload airwave upgrade package. Make sure that you put this under /user directoryCapture.JPG
    5. After uploading the package to /user directory. Login to Airwave using Putty session.  Change the value to 30 to 60 seconds for sending of null packets to keep session activeAW5.png
    6. Do the local upgrade and you will see version 8.2.10.1 as one of the  option. Select this version and it will start the upgrade.
    Sample airwave commands (step 6)
