How to upgrade an IAP 115 using the cli
This thread has been viewed 21 times
  • 1.  How to upgrade an IAP 115 using the cli
    Posted Jul 23, 2014 11:20 AM
    How do I upgrade system firmware using the CLI?
  • 2.  RE: How to upgrade an IAP 115 using the cli
    Posted Jul 23, 2014 12:10 PM
    Upgrading an Image Using CLI
    To upgrade an image using a HTTP, TFTP, or FTP URL:
    (Instant Access Point)# upgrade-image <ftp/tftp/http-URL>
    To upgrade an image without rebooting the IAP:
    (Instant Access Point)# upgrade-image2-no-reboot <ftp/tftp/http-URL>
    To view the upgrade information:
    (Instant Access Point)# show upgrade info
  • 3.  RE: How to upgrade an IAP 115 using the cli
    Posted Jul 23, 2014 01:10 PM
    Thanks Seth - this worked great!  Tftp was taking too long so I installed an Apache http server and it was able to upgrade pretty quickly after that.  The Internet connection at this location is not very good and it would fail to upgrade when using the GUI.
  • 4.  RE: How to upgrade an IAP 115 using the cli
    Posted Nov 28, 2016 02:33 PM
     Can i use the same commands for an ap225? I'm adding an ap225 to a virtual controller (ap135).
  • 5.  RE: How to upgrade an IAP 115 using the cli
    Posted Nov 29, 2016 05:06 AM
    Yes.
  • 6.  RE: How to upgrade an IAP 115 using the cli
    Posted Jun 07, 2017 02:13 PM
    Will the cmd work in apboot mode on a IAP 105? If not, how to upgrade if no DHCP server and not joining to cluster?
  • 7.  RE: How to upgrade an IAP 115 using the cli
    Posted Apr 22, 2019 10:37 AM
    Are we able to upgrade the ap image from the cli using the console commands (purgeenv and saveenv level)?
