How to upgrade OS to 6.1.3.14
  • 1.  How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 09:00 AM
    how to i upgrade firmware from  ArubaOS 5.0.3.3  to  6.1.3.14? plz i need steps?
    Controller: Aruba 3600
    Firmware: AOS 5.0.3.3
    Thanks.
  • 2.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 09:02 AM
    Do you have the release notes for that version? It will guide you step by step.
    Tim
  • 3.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 09:03 AM
    Please look in the 6.1.3.14 release notes for detailed instructions on how to upgrade.
  • 4.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 09:04 AM
    <EDIT>
    Please follow this release note.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_ViewDetails/Default.aspx?EntryId=15671
    Sorry Boneyard I didnt noticed that, I thought I am pasting PDF link from internet.
    Thanks for correction :)
  • 5.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 09:28 AM
    dont think we can access your computer suman :)
  • 6.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 11:21 AM
    thanks friends ,, how long it take normally?
  • 7.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 05, 2015 03:42 PM
    that depends on several things, ammount of APs, connection speed to APs, how fast you type :)
    not sure how many steps you exactly need, as mentioned read the release notes for that. but on average count of half an hour till an hour per step if you got everything we prepared. else it might be a little longer.
    if you can i would do this on a quiet moment, after office hours in a weekend, ... so you got all the time to go through the steps.
  • 8.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 06, 2015 07:32 AM
    that is right, i will try to do that
    thanks all
  • 9.  RE: How to upgrade OS to 6.1.3.14
    Posted Jul 13, 2015 03:27 AM
    The solution is :
    first current version must be upgrade to version 5.0.4 and after that to version 6.1.3
    Thanks all
