last person joined: 2 hours ago
How to use AP93 ( Config, No Controller, No light 11A/N & 11B/G/N, ......)
  • 1.  How to use AP93 ( Config, No Controller, No light 11A/N & 11B/G/N, ......)
    Posted Sep 05, 2014 07:29 AM
    Hi all,
    I have an AP93 ( only router, AC-DC Adapter ).
    I Turn on my AP93 and only LED PWR are flashing. LED 11A/N and 11 B/G/N are off.
    I have to try connect my AP with PC via Console cable and using Hyper Terminal show are
    apboot> mfginfo
    Manufacturing info:
    System S/N : BU0xxxx
    Date Code : 100913
    Base MAC : 24:de:c6:c1:xx:xx
    MAC Count : 1
    CPU Assembly : 0AR5xxxx
    CPU Major Rev : 10
    CPU Brd Variant : 01
    CPU Board S/N : R539Oxxxx
    PROM Format : 1
    Checksum : 9f
    apboot> osinfo
    Partition 0 does not contain a valid OS image
    Partition 1 does not contain a valid OS image
    apboot>
    I Think my all not install OS Image. Please help me to use this ap.
    I haven't controller. I only have Console cable ( RJ45 => DB9 ).
    Many Thanks,
  • 2.  RE: How to use AP93 ( Config, No Controller, No light 11A/N & 11B/G/N, ......)
    Posted Sep 05, 2014 07:32 AM
    If the model is "AP-93" and not "IAP-93", you need a controller.
