Developer
How to use Central API to indentify an device on a switch port
  • 1.  How to use Central API to indentify an device on a switch port
    Posted Oct 06, 2020 03:03 PM
    I'am close to a PowerShell solution to zero-touch-provisioning AP's and SW's to a site in Aruba Central.
    Everything like creating a site, looking for new devices, adding a switch to a site, renaming the SW and AP, assigning a new IP to the SW and AP is possible with the API calls. The only solution i'am still looking for, is to identify a access point connected to port 10 and 22 of the switch. So I can give a AP the correct IP number. I know I can see (manually) a MAC address in Central (LLDP), but I cannot find a proper way to do it within powershell (API calls).
    Can somebody point me in a good direction.
    Many thanks!!
  • 2.  RE: How to use Central API to indentify an device on a switch port
    MVP GURU
    Posted Oct 09, 2020 03:51 AM
    Hi Japie
    Nice, do you plan to share the script ?
    you search how to get LLDP from Central ? for a specific switch ?
