how to use CLI configure 802.11b/g/n
  • 1.  how to use CLI configure 802.11b/g/n
    Posted Jun 14, 2016 08:09 PM
    I'm using Aruba Instant AP 225 and 205 and I'm new to Aruba product.
    There is a option "Legacy Only" in the WebUI to enable 802.11b/g or 802.11b/g/n.
    If possible, I'd like to know if there is any CLI command can force the AP use 802.11g only, or 802.11n only? In some cases, I also want to change MCS index and try 802.11n HT20 or 802.11n HT40.
    Any anyone help me out?
    My Aruba OS is 6.3.
    Thank you for your help.
  • 2.  RE: how to use CLI configure 802.11b/g/n
    Posted Jun 17, 2016 01:05 AM
    Hi
    you found here the CLI guide of the InstantOS version 6.3
    Regards
