how to use dhcp scope in latest firmware ?
  • 1.  how to use dhcp scope in latest firmware ?
    Posted Sep 23, 2014 03:12 AM
    hy,
    i'm trying to use dhcp scope features, but it seems i'm failing apart :(
    here is my setup:
    i have 3 IAPs:
    - 2 SSID
    i'm trying to create another one, that would offer IP adresses on 10.2.1.0/24 Vlan 11
    i've created a local dhcp scope , assigned it to my new SSID
    but trying to connect to the SSID failed ! :(
    find attached an SS of my DHCP configuration.
    if anyone have a clue ... :)
  • 2.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 23, 2014 05:53 AM
    Did you statically assigned the VLAN ?
  • 3.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 08:34 AM
    here is how my SSID is configured (sorry for the french interface).
    see file attached
    by the way, french translation doesn't seem to be completed :)
  • 4.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 09:28 AM
    What type of authetnication are you using on that SSID ?
  • 5.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 09:30 AM
    thanks for your reply :)
    i'm using WPA & WPA2 Personnal
    without any restriction
  • 6.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 09:48 AM
    Are you able to get an ip address if it an open SSID by any chance ?
    Is it happening with any type of device ?
    Can you please share your ACL rules attached to that network ?
  • 7.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 10:12 AM
    hy again :)
    no ip allocated even in open mode
    tested with my dell laptop (ubuntu 14.04), my smartphone : android 4.4 samsung
    same behavior :(
  • 8.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 12:51 PM
    This only happens when you assign a static VLAN with an internal dhcp scope , correct ?
    You should change the selection to network assigned instead , I just noticed that
  • 9.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 12:59 PM
  • 10.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 01:30 PM
    Tested on lab using the latest code on a IAP-135 and it worked
  • 11.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 01:55 PM
    Nice,
    Can please explain your setup?
    Maybe it would give me someone input.
  • 12.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 02:15 PM
    Nothing complex
  • 13.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 02:20 PM
    Indead!
    Can my problem be related to the fact that i already have a default dhcp
    scope on another range?
    This detail is just poping out of my mind.
    Regards
  • 14.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 03:15 PM
    Uhmm can you please share your config
  • 15.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 25, 2014 03:17 PM
    Sure, i will by tomorrow morning as i'm home for now 😁
    Thanks for your help,
    Regards
  • 16.  RE: how to use dhcp scope in latest firmware ?
    Posted Sep 26, 2014 03:15 AM
    Please find attached the full setup.
    i still don't know why it's not working :(
    FYI the VLAN ID used in only defined in the IAP .
    i'm really knocking my head on this :(
    by the way the actual firmware is 6.4.0.3-4.1.0.2
    i just noticed an update available to 6.4.0.3-4.1.1.0
  • 17.  RE: how to use dhcp scope in latest firmware ?
    Posted Oct 02, 2014 09:21 AM
    any update on this knocking head issue maybe ? :)
    Regards
  • 18.  RE: how to use dhcp scope in latest firmware ?
    Posted Oct 02, 2014 09:37 AM
    Your config looks good .
    - You may want to try upgrading one of your IAPs and test the config there and if it works then upgrade your cluster
  • 19.  RE: how to use dhcp scope in latest firmware ?
    Posted Oct 02, 2014 09:39 AM
    i'll try and let you know then
    Thanks for the follow up
