Network Management
  • 1.  How to Use Gmail as Airwave Mail Relay?
    Posted Nov 16, 2015 10:05 AM
    Gmail's mail relay used tcp 587 and need to be authenticated with username and password.
    But I don't know how to configure...
  • 2.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Nov 16, 2015 10:11 AM
    You need to configure postfix on Airwave manually.  Please see the attached.
    Attachment(s)
    pdf
    AIRWAVEwGMAIL.pdf   127 KB 1 version
  • 3.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Nov 16, 2015 04:36 PM
    Just FYI authentication is not mandatory. The Google relay can be configured to accept mail from trusted IP's.
  • 4.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Nov 17, 2015 02:32 AM
    Airwave can send mail via gmail now.
    Thanks a lot!!!
  • 5.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Feb 22, 2018 02:27 PM
    Thank you, I was able to use this document to get airwave connected to office365 smtp server.
  • 6.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Mar 11, 2019 09:48 AM
    Is this still required for 8.2.8.1?
    I attempted to run the commands but they didnt work via ampadmin->"11 Enter commands"
    https://www.booches.nl/2017/09/aruba-airwave-and-shell-access/
  • 7.  RE: How to Use Gmail as Airwave Mail Relay?
    Posted Mar 11, 2019 10:02 PM
    As an ampadmin user you will have only limited access to Airwave CLI. Hence, wont be able to configure. You would need the shell access if we have to modify any file. You would have to open a support case as TAC can help you with the configuration from shell.
