How to use the telnet CLI on an AP? Permission Denied on every command.
This thread has been viewed 44 times
  • 1.  How to use the telnet CLI on an AP? Permission Denied on every command.
    Posted Oct 30, 2019 04:16 PM
    I have an issue that I need to troubleshoot from the AP's perspective, but having trouble using telnet.
    I can set up the telnet option using the Profile -> AP System, and I can successfully telnet to the AP. However, once I'm in the telnet session every command I try is met with an error message saying that I don't have permission.
    Specifically I want to run commands on the AP such as ping, traceroute, show arp, show mac address table.
    <<DELETED a lot of text here because it wasn't relevant to the telnet question>>
  • 2.  RE: How to use the telnet CLI on an AP? Permission Denied on every command.
    Posted Oct 30, 2019 04:49 PM
    I found something to try.
    ctrl+k
    Apparently this will get into full shell.
    Will try it out and report back here.
    Edit: Confirming that yes, you can use esc followed by ctrl+k and you will then have access to a (still limited) BusyBox shell.
