How to verify an IAP has been converted successfully to a Campus AP?
  • 1.  How to verify an IAP has been converted successfully to a Campus AP?
    Posted Jan 09, 2018 08:16 PM
    After converting IAP 325 to a campus AP using the command line via console after AP reboot, I am trying to verify through the console if the conversion has happened successfully? Both "sh version" and "sh about" provide little clue. Seems like there doesn't exist a single command that can identify the current state of an AP i.e. Instant, Campus or Standalone.
  • 2.  RE: How to verify an IAP has been converted successfully to a Campus AP?
    MVP EXPERT
    Posted Jan 10, 2018 04:06 AM
    You should be able to verify using the below commands:
    # show swarm mode
    # show ap-env
    Take a look here for further examples:
    http://www.arubanetworks.com/techdocs/Instant_40_Mobile/Advanced/Content/CLI_commands/show_swarm_state.htm
  • 3.  RE: How to verify an IAP has been converted successfully to a Campus AP?
    Posted Jan 10, 2018 04:24 AM
    If the AP is successfully converted to a campus AP, you will no longer be able to login. So if you have a login prompt, it is not converted to a Campus AP.
    The console of a campus AP (either native or cobverted) will show a prompt like this on the console:
    shutting down watchdog process (nanny will restart it)...
            <<<<<       Welcome to the Access Point     >>>>>
    password: <if you type the AP group password here>
    If you want to troubleshoot the conversion process, run after the conversion started the command:
    show log convert
    And on the controller, a 'show log all' to check if the AP is connecting to the controller.
