How to verify enhanced open on instant 8.4.0.0
  • 1.  How to verify enhanced open on instant 8.4.0.0
    Posted Jan 15, 2019 08:49 AM
    hey airheads,
    i updated an instant setup to 8.4.0.0 yesterday in a lab enviroment, setup an SSID with captive portal and activated enhanced open.
    tested with a android 9 phone patchlevel 2018-12-01, snapdragon 845.
    How to verify if OWE is active?
  • 2.  RE: How to verify enhanced open on instant 8.4.0.0
    MVP EXPERT
    Posted Jan 15, 2019 09:08 AM
    You can verify this using the command 'show ap bss-table', if you look for the O/o flags this will advise if it is OWE enabled.
    Flags:       K = 802.11K Enabled; W = 802.11W Enabled; 3 = WPA3 BSS; O = OWE Transition mode OWE BSS; o = OWE Transition mode Open BSS; M = WPA3-SAE mixed mode BSS
    Does the device in question support OWE? If you wish to disable transition mode so it is strictly OWE use the below command:
    wlan ssid-profile
     opmode-transition-disable
     The command 'show ap association' will also show if the client has an O flag next to it:
    Flags: H: Hotspot(802.11u) client, K: 802.11K client, M: VHT Mu beam formee, R: 802.11R client, W: WMM client, w: 802.11w client, V: 802.11v BSS trans capable, P: Punctured preamble, U: HE UL Mu-mimo, O: OWE client, S: SAE client, E: Enterprise client
  • 3.  RE: How to verify enhanced open on instant 8.4.0.0
    Posted Jan 15, 2019 09:21 AM
    sadly there is no information from qualcomm if the snapdragon 845 already supports OWE. There ae only announcements  it will support wpa3 but no confirmations or device lists.
  • 4.  RE: How to verify enhanced open on instant 8.4.0.0
    Posted Jan 31, 2019 05:01 AM
    More testing done:
    Android (Mi 8 Pro) Supports OWE
    AP303h ************************ y y 1 1 _owetm_TEST3484306596 1 a-VHT-80sgi-2ss 1m:16s 1 WVwMO Yes (Implicit) 0.0.0.0
    Iphone 8 does not support OWE
    AP303h ********************** y y 1 20 TEST 1 a-VHT-80sgi-2ss 7s 1 WV Yes (Implicit) 0.0.0.0
    But when the Android is connected via OWE the captive Portal is not working and i get a 404.
    Can Anyone Test this?!
