you can add the allow-listed sites for any captive portal.
Here I am using a BYOD Provision role that redirects to the onboarding URL but also allows other domains which are needed for Android devices.
Original Message:
Sent: May 26, 2024 03:38 PM
Subject: How to whitelist hosts from external captive portal
Hi there,
So, I need to send users to captive portal via a role.
I can do it using DUR and/or using the aruba role VSA but what I can't see is how to allow access to some sites when still on captive portal. Whenever I add the Captive Portal rule to the role it will always to to the first position. So, no way to allow stuff before captive portal rule activates.
