How to whitelist hosts from external captive portal
  • 1.  How to whitelist hosts from external captive portal
    Posted 29 days ago
    Hi there,
    So, I need to send users to captive portal via a role.
    I can do it using DUR and/or using the aruba role VSA but what I can't see is how to allow access to some sites when still on captive portal. Whenever I add the Captive Portal rule to the role it will always to to the first position. So, no way to allow stuff before captive portal rule activates.
  • 2.  RE: How to whitelist hosts from external captive portal
    Posted 29 days ago
    you can add the allow-listed sites for any captive portal.
    Here I am using a BYOD  Provision role that redirects to the onboarding URL but also allows other domains which are needed for Android devices.
  • 3.  RE: How to whitelist hosts from external captive portal
    Posted 29 days ago
    Oh, I see.
    I was mislead by the fact that "Enforce captive portal" was always on the top of the list, making me think it would always match and ignore all the rules bellow it.
    Great to know that is not the case.
