How USB mount to 7210 controller?
This thread has been viewed 148 times
  • 1.  How USB mount to 7210 controller?
    Posted Jan 11, 2015 04:52 AM
    Hello!
    How USB mounted to 7210?
    Exactly I have to know - how USB named.
    Have no access to CLI of Controller, and in GUI don't see this information.
    When try to copy files from controller - wrong partition.
    Thank you!
    #7210
  • 2.  RE: How USB mount to 7210 controller?
    Posted Jan 11, 2015 06:12 AM
    #7210
  • 3.  RE: How USB mount to 7210 controller?
    Posted Jan 11, 2015 06:27 AM
    usb should be fat32 formatted, put it in the 7200 and then use show storage to check it has mounted.
    (sg-7210) #show storage
    Filesystem                Size      Used Available Use% Mounted on
    none                      2.0G     18.6M      2.0G   1% /tmp
    /dev/usb/flash3           1.5G    110.3M      1.3G   8% /flash
    /dev/usbdisk/slot0/1      7.4G    186.0M      7.3G   2% /mnt/usbdisk/slot0/1
    (sg-7210) #
    note the "partition" number, here is 1  (i.e. /mnt/usbdisk/slot0/<partition #>).
    then, you can use CLI as follows:
    >> put something on it
    (sg-7210) #copy flash: default.cfg usb: partition 1 default_11jan15.cfg
    ....File default.cfg copied to /mnt/usbdisk/slot0/1/default_11jan15.cfg successfully.
    (sg-7210) #
    >> perform directory listing
    (sg-7210) #dir usb: partition 1
    Listing /mnt/usbdisk/slot0/1
    -rwxr-xr-x    1 root     root     97505424 Jan  8 09:22 6.4.2.3_47524.img
    drwxr-xr-x    2 root     root         4096 Jan 12  2015 Arubaimage
    -rwxr-xr-x    1 root     root           11 Jan 12  2015 blah.TXT
    -rwxr-xr-x    1 root     root        37439 Jan 11 19:23 default_11jan15.cfg
    (sg-7210) #
    >> perform upgrade image
    (sg-7210) #show image v
    Partition               : 0:0 (/dev/usb/flash1) **Default boot**
    Software Version        : ArubaOS 6.4.3.0 (Digitally Signed - Production Build)
    Build number            : 45897
    Label                   : 45897
    Built on                : Wed Sep 10 02:57:26 PDT 2014
    Partition               : 0:1 (/dev/usb/flash2)
    Software Version        : ArubaOS 6.3.1.5 (Digitally Signed - Production Build)
    Build number            : 43118
    Label                   : 43118
    Built on                : Tue Apr 8 20:55:04 PDT 2014
    (sg-7210) #
    (sg-7210) #copy usb: partition 1 6.4.2.3_47524.img system: partition 1
    Upgrading partition 1
    File 6.4.2.3_47524.img copied to partition 1 successfully.
    The system will boot from partition 1 during the next reboot.
    (sg-7210) #
    Software Version        : ArubaOS 6.4.3.0-frogsleap (Digitally Signed - Production Build)
    Label                   : 45897
    Partition               : 0:1 (/dev/usb/flash2) **Default boot**
    Software Version        : ArubaOS 6.4.2.3 (Digitally Signed - Production Build)
    Build number            : 47524
    Label                   : 47524
    Built on                : Sat Dec 6 10:15:29 PST 2014
    (sg-7210) #
    Note: If you want to use the front panel to do the upgrade, you need to ensure the image is in a subdirectory called Arubaimage as noted in the userguide in the section "Using the LCD Screen", but if you just want to access and use the USB after the controller has booted, then this doesn't have to be the case.
    regards
    -jeff
    #7210
  • 4.  RE: How USB mount to 7210 controller?
    Posted Jan 11, 2015 03:16 PM
    Thank you for reply!!!
    BUT
    I can copy configuration to usb-flash through CLI, but Customer want to periodically backup config, he don't know CLI, so he want to backup through GUI.
    In GUI I can't find name of partition.
    I have to type in GUI, in COPY-TO-USB menu, this?
    #7210
  • 5.  RE: How USB mount to 7210 controller?
    Posted Jan 11, 2015 04:11 PM
    That is correct.
    The more practical way would be to copy it off to a server via SCP or FTP.
    Do you have AirWave? AirWave backs up the controller every night.
    #7210
  • 6.  RE: How USB mount to 7210 controller?
    Posted Jan 11, 2015 04:14 PM
    Thank you for help!
    #7210
  • 7.  RE: How USB mount to 7210 controller?
    Posted Mar 07, 2017 05:39 PM
    Hi everyone!!
    For doing it via GUI, at least in ArubaOS 6.4 or 6.5 (I don't know if you can do it in older versions), you can go to Maintenance->Files->Copy Files there make the selection of the file to copy in source, and then in destination checks USB and write 1 on partition and the nameofthefile in the name box.
  • 8.  RE: How USB mount to 7210 controller?
    Posted 30 days ago
    One note that might be a given for some, put the usb drive in and reboot the controller so it mounts the usb. I couldn't find a way to mount the usb with the controller up and inserting the usb. It auto mounted it with the usb installed and then rebooting the controller.
  • 9.  RE: How USB mount to 7210 controller?
    Posted 29 days ago
    I am doing automatic backups from a script on Linux server (SCP) that emulate CLI to the MCR & MD. Script run from CRON
    You can try to adapt it for saving to USB as the script is simple
    Regards
    Christian Chautems
    Attachment(s)
