Wired Intelligent Edge
  • 1.  HP 10500 switch with internal firewall
    Posted Feb 12, 2024 12:47 PM
    hello,
    my customer has HP 10500 switch. with internal firewall SecBlade  and need to upgrade the switch firmware the question is can we upgrade the switch firmware without upgrading the internal firewall? if yes what about compatibility?
  • 2.  RE: HP 10500 switch with internal firewall
    Posted Feb 12, 2024 02:46 PM
    Hi, AFAIK the Switch (hosting the SecBlade module) software version (both the running one and also the one you want the Switch be updated to) imposes SeBlade minimum required software versions. Check HPE 10500 release notes.
