I was attempting to setup link aggregation with a Synology RS812 NAS and the switch froze. I've attempted (multiple times) to reset the switch to factor defaults by:
- Holding down the "Reset" and "Clear" on the front panel
- Releasing "Reset"
- Releasing "Clear" after the LED Mode lights flash twice
The switch will not come up completely. Fault indicator is flashing and ports 9-16 have the link light blinking. This configuration implies fault other than self-test. This says configuration fault to me, but I thought I was following the instructions to reset to factory defaults above.
Ideas?
P.S. This thread has been moved from ProCurve / ProVision-Based to Web and Unmanaged - HP Forum Moderator
#reset#hp1810
