Network Management
HP-1910-48g-switch-jg540a
  • 1.  HP-1910-48g-switch-jg540a
    Posted Nov 29, 2023 02:32 PM
    My HP switch 1910-48 JG540A won't boot . i've tried to reset it but i get this answer :
    Password recovery capability is enabled. To perform this operation, first
    disable the password recovery capability using the undo password-recovery
    enable command in CLI.
    so i put "Skip Current System Configuration " and i reboot i get this answer :
    BootWare Validating...
    Press Ctrl+B to enter extended boot menu...
    Starting to get the main application file--flash:/JG540A-CMW520-R1106.bin!..
    The main application file is invalid!
    Starting to get the backup application
    file--flash:/JG540A-CMW520-R1106_bak.bin!
    The backup application file does not
    exist--flash:/JG540A-CMW520-R1106_bak.bin!
    Starting to get the secure application file--flash:/secure.bin!
    The secure application file does not exist--flash:/secure.bin!
    Booting App fails!
    i want to update the firmware but i I can't find the firmware on the website .
    https://h10145.www1.hpe.com/support/SupportLookUp.aspx
    can some one help me please ?!
  • 2.  RE: HP-1910-48g-switch-jg540a
    Posted Nov 30, 2023 06:04 AM
    Hello
    Last firmware version is R1519P06
    It's downloadable from Aruba Support Portal : https://asp.arubanetworks.com
    (Create an account if needed, to access
    The Release Notes describe the method for upgrading software from Boot ROM menus (Appendix B, you will need a TFTP server on your machine)
    Frederic MEUNIER
  • 3.  RE: HP-1910-48g-switch-jg540a
    Posted Dec 05, 2023 04:36 AM
    Thank you for your feedback.
    do you have a tutorial to follow to update the firmware please knowing that I can't access through the console only?!
    Thank you
