Comware
HP 1910-8G, NFS/CIFS between VLAN
  • 1.  HP 1910-8G, NFS/CIFS between VLAN
    Posted Feb 10, 2014 11:03 PM
    Good day.
    I have some problem with HP 1910-8G Switch JG348A
    Software Version
    5.20 Release 1513P66
    Hardware Version
    REV.A
    Bootrom Version
    167
    Settings:
    1-4ports - VLAN 1
    5-8ports - VLAN 99
    ip address:
    VLAN1 - 192.168.7.238/24
    VLAN99 - 192.168.99.1/24
    I connected computer1 to port 1 with such settings:
    192.168.99.2/24
    GW - 192.168.99.1
    And computer2 to port 5:
    192.168.7.99/24
    GW - 192.168.7.238
    The "pings" work good in both direction from computer1 to computer2 and the other way as well.
    From the computer1 I can open webpage from the local web-server (192.168.7.99).
    But i can't open sharing resources - when i try to open it I've received this error - "\\192.168.7.99.The Network Path Cannot Be Found"
    If both computers are in the same network - 192.168.7.0/24 it's working without any problems.
    It's a similar problem here -
    http://h30499.www3.hp.com/t5/Web-and-Unmanaged/HP-Procurve-1810G-24-quot-Auto-DoS-quot-prevents-NIS-and-NFS/td-p/4693460#.Uvmb5WJ_upA
    But i can't find any setting in web-management about DOS-prevention in my HP-1910-8G, although in the description of this switch there is such feature - "automatic denial-of-service prevention".
    Thanks in advance for any help.
    #hp1910
    #CIFS
    #NFS
    #VLAN
